B
Barr26
Hello,
I've been recording songs/albums for a while, but recently switched to a MacBook Pro, using Logic Pro X for my mixer and, since I have no drums or access to a drummer, Ableton LIVE! for that. I'm just a couple songs into my new album and realizing that I'm going to need to break down and finally start using compression and EQ on each drum kit piece as I go forward (I was always lazy about it in the past, but it's time to do it right).
I'm pretty sure I can use LIVE to adjust each piece with no problem and keep rendering to a WAV and importing into Logic, but it would seem that since I'm doing all my other mixing in Logic, I'd want to do the same with the drums. But if I have a beat that contains a kick, snare, hitat, and whatever else, then I won't be able to adjust each piece in Logic.
I realize I'm stating the obvious, but it leads to my main question; those who have worked with drums in this way, how do you prefer to go about it? Do you try to perfect your drum sounds in your drum creator before importing, or somehow mix them properly after they are in your DAW?
I hope that makes sense. Thanks!
-Rick
-Rick
