Earthworks mics
  • Thread starter Thread starter Marik
Marik
Marik
Pro Microphone Design
Gentlemen,
Extremely important!!!
I need close up pics of Earthworks capsule head of any model and/or at least its dimentions (mostly diameter). Is it ribbed (like ECM8000) or not?
Grazie, Marik
Here's a quick pic of the QTC-1. The tip is 1/4 in. diameter, it is not ribbed.
Thank you DigitMus,
You cannot imagine how helpfull it was! :cool:
One more question: what kind of grill it has, or is it just a black fabrik jobbie on the tip?
It's a metal mesh - kind of inside the tip, flush with the top.
SG
I have a pair of SR-71's. It's like DigitMus describes.
Thank you Gentlemen,
Can you tell one more thing. If you ever seen WM60 or many other small electret capsules, the diameter of the body is about 5 mm, and the hole on the tip is only 2 mm. Can you see what is the diameter of this hole on Earthworks?
The last couple inches of the housing are just a metal tube, so the "hole" is the diameter of the the tube (1/4 in. - about 6.5mm) minus the thickness of the tube walls (about 1mm) - so I'd guestimate the "hole" at 4.5mm.
SG
Earthworks capsule investigation
Marik,
Are you trying to determine if Earthworks uses panasonic capsules?
I can tell you a short story about the orginins of Earthworks mics...around 1991 David Blackmer (dbx / Earthworks founder) sat down at my desk at and dumped out a bag of Panasonic capsule and proceeded to take them apart. He performed the Linkwitz mod on them but was also interested in bypassing the internal FET.
He and I looked also looked over wire mesh and extruded tubing catalogs for suitable measurment mic parts.
Rumor has it that current Earthworks mic use special capsules but I can assure you the earliest models were built from stock Panasonic parts subjected to the Linkwitz mod.
cheers, MJ
Re: Earthworks capsule investigation
<The last couple inches of the housing are just a metal tube, so the "hole" is the diameter of the the tube (1/4 in. - about 6.5mm) minus the thickness of the tube walls (about 1mm) - so I'd guestimate the "hole" at 4.5mm.>
Thank you DigitMus!
MichaelJoly said:
Marik,
cheers, MJ
Michael,
Good to see you back! Thanks for the information.
No, not all I am trying to investigate origin of Earthworks capsules--just researching for my ECM8000 mod.
Primarily... I thought that small input diameter of the capsule and cavity between body and diaphragm create a resonator for flat response, and the little black jobie is a part of this. What happens when we remove this resonator?
I talked to David at one of the AES shows and he mentioned that he was using a special Panasonic capsule made just for his microphones.
