A
audiodudero
Hey guys need some advice here.
My guitar sound is coming out gross - sounds terrible.
If I am going acoustic electric guitar -> duet 2 -> mac -> logic x
What are the proper input levels and settings so I can have the cleanest noise / signal coming through before effects, eq, noise gates, and compressors. Right now I get hiss and the guitar is either too quite or too loud. I want to be able to play at low volumes, but high clean harmonics, finger picking and palm mute strums and then loud strumming and guitar slapping percussion. ALL I want the signal to be as quite as possible before having to alter the track.
DUET 2 SETTINGS QUESTIONS: - BEST TUNE UP SETTINGS FOR EACH:
Input Setting: inst or -10 or +4
What should I set the DB knob to?
Should the A on the left be highlighted?
Line 1 Output +4bu or -10dbv
Line 2 Output +4bu or -10dbv
Line 1 Volume
Line 2 Volume
___________________
MIXER:
SOFTWARE RETURN VALUE:
MIXER MASTER VALUE:
_______________
SAMPLE RATE: 44.1
PEAK HOLD: 2 SECONDS
OVERHOLD
____
eLECTRIC aCOUSTIC
Volume on the pickups 1-10
____________________
Mixer SEttings:
Software Return: 0
Mixer Master: 0
_______________
LOGIC X PRO
AUDIO PREF
I/0 BUFFER - 64
RECORDING DELAY 0
24 BIT RECORDING CHECK
SOFTWARE MONITOR - CHECK
INPUT MONITOR ONLY FOCUSED TRACK AND RECORD ENABLED - CHECK
INPUT MOINTOR FOR RECORD ENABLE CHANNEL STRIP - NOT CHECKED
PROCESSING THREAD: AUTO
PROCESS BUFFER FLANGE: MEDIUM
REWIRE BEHAVIOR: OFF
MAXIMUM SCRUB SPEED: NORMAL
SCRUB RESPONSE: NORMAL
Please help - I know long question - but I will take your valuable information to the grave!!
ALSO: If you have a good looking track record / CV and you want to take the time to fill this information out for me PM me and we can discuss rates for your time.
Please HELP!
Line 1 Volume
Line 2 Volume
___________________
MIXER:
MIXER MASTER VALUE:
_______________
SAMPLE RATE: 44.1
OVERHOLD
____
eLECTRIC aCOUSTIC
Mixer SEttings:
Software Return: 0
Mixer Master: 0
_______________
LOGIC X PRO
AUDIO PREF
I/0 BUFFER - 64
RECORDING DELAY 0
Please HELP!
