A
axeman_ukl
something i'm not a 100% sure of :-
i know it has two cores but does one have to max out one in cpu power before the other fires up or do they both run at the same time sharing the work equally in the one program ?
or does one run one program only and the other is there if you boot up another program ?
also 64 bit means you can use more memory is this (if say you have 4gig of memory that sonar would be able to use it all or would the memory be divided equally between the cores 2gig for core 1 2gig for core 2 )
hope somebody can shed some light on this
