Booda
Master of the Obvious
I'm also wondering if it works on a 333 FSB.???
I have a MSI nForce2 Ultra 400 MB, 512 Kingston HyperX 3200 RAM, and a AMD AthlonXP Barton 2800+ (it's 333 FSB). So for me to do this I need to run everything at 333, correct? Which seems it would be easier on the MB and RAM.?.
I want to add another 512 HyperX and run dual channel (my MB supports it). BUT I've been told several conflicting opinions.
1a. To run Dual Ch. you need a "Kit" w/ matched sticks from the manufacture. (even the same model may have different chips on them depending on when it was manufactured)
1b. "Any 2 sticks that are the same model will work... it worked for me" ... so the person says. He also said he's ran Dual CH w/ 2 sticks by different manufactures. Hmmmmm??? I wonder about that one.
2. My MSI Motherboard Users Guide says it supports DDR 266,333,400 and it will run Dual CH if you install in Dimm 1 and 3. But I talked to a guy last week that said to run Dual CH. everything has to support 400 FSB or you won't see a performance increase. It happened to him he said after trying it at 333 FSB. although he builds PCs for a Networking Co. I don't think he knows what he's talking about.
What should I do? I think if I run my System at 333 it will all be OK... but should I just get all new RAM or will just adding another stick of 512 HyperX be ok.
Thanks,
B.
Thanks,
B.
