Drumkit From Hell
  • Thread starter Thread starter jerberson12
J
jerberson12
mucis procedure
My "Drumkit from Hell" just arrive.......EWWWWWW This one sucksssss.......Or should I say......
Why does there demo's from toontrack seems to be different than the wave files on the disk? Maybe i should switch to Discrete Drums. Or maybe I dont really knwo how to process drum sound.........????
Are you using the multi format with mapping ??
Are you using wet or dry ??
Rock Kit or Jazz ??
cH or rH ??
The samples are the same as the demo I assure you. You have to consider velocity and other parameters that make up the demo. The demo is not just raw samples, it was tweaked thru the sampler to get that sound which you can also do.
