R
RAMI
Guest
I think it's a simple case of mixing up terms. Every mic needs a pre-amp, or "pre-amp power" as you put it. That's not the same as "Phantom power".
Thanks everyone. I looked up the Focusrite liquid saffire, It seems pretty cool but once again I am retarded and can't understand it fully, like Karl Childers reading the bible...Guitar Center dudes don't usually know what are they talking about (with some rare exeptions), so forget everything they have told you
Anyway the first guy was right - you need phantom power only for condenser mics.
I'm using Focusrite Liquid Saffire 56 firewire interface for about half year now - great interface imo
The most reliable source imaginable under the circumstances ~ himself !Also, you say "apparently I need at least nine preamps" ?
According to whom?
You would be better off buying an interface with enough preamps built in, to mic your kit. How many mics are you using?
9 right now but I might add 3 more
I don't know I'm just going off what you guys are telling me. From what I now understand I need a preamp for every mic and phantom power for the condensers. all of those total 9 as of now. My kit is large and sounds incredible and I want that to come through in recording, so not micing every drum isn't an option for me. Any interface recommendations would be appreciatedThat focusrite has 6 preamps and bucketloads of other stuff that you don't need.
I'd recommend either blindly taking Jimmy's advice, or taking some time out to read and fully understand what you're buying.
There are plenty of threads here that outline the basics.
Either option will save you a lot of cash.
EDIT
According to whom? I'd start with four, (kick snare and two overheads) then see how you get on.
You may be surprised how many people here started out with a million kit mics and then gradually 'progressed' to four or so.
It totally depends on what you're recording though, so don't get me wrong, you might need nine for all i know.
All of this depends on what style of drumming and genre of music he is playing. A 3 or 4 mic setup will not work for a kit with 2 kicks and 5 toms in a prog metal-type situation. It just wont. In anything remotely like that, you don't/can't rely on the overheads to get most of the drum sound.
I've been known to use 11 mics on a 5 piece kit.
Inside and outside kick
top and bottom snare
toms 1,2,3
hat
ride
2 overheads
There is absolutely nothing wrong with micing everything , and that is the only way to get certain drum sounds.
While I agree that if he is playing a style of music that would take kindly to the 3 or 4 mic setup, it would be a good thing to do, but somehow I'm getting the idea he is doing something that requires a close miced setup.
Yes, I agree with both you guys. If it sounded like I was saying he SHOULDN'T use 9 mics, that's not what I meant. It just seemed like he was thinking that throwing up 9 mics on his kit will pbe a pic-nic. My point is that, if his kit does sound as awesome as he's saying, that won't automatically be re-produced by throwing a mic at every drum and cymbal. The overheads is still where most of the meat of his sound should come from, and unless one has at least a basic knowledge of overhead micing techniques and avoiding phase issues, etc....it's not going to be as easy as he might think.Yup. I've miked drums with anything from 3 mics to 10 or more. It all depends on what you're after (and what resources you have available).
Thanks for the advice! The mics are OK, they are Audix D2's, D4's, D6's, i5, and ADX51 overheads. I am going to replace the overheads soon, notYou really seem intent on using a mixer. You also seem intent on spending lots of cash. That ZED-R16 is a beautiful piece of equipment. Someone who really knew how to massage that mixer properly would be able to get amazing results.
Since you still seem stumped on very basic issues here, I would recommend - as others already have - that you start simple and get a sound you're happy with and then expand as necessary.
It's awesome that you have a top-of-the-line drum kit. As far as I know, you haven't mentioned exactly which mics you're using. The mics will affect your sound considerably. Unless you are using incredible mics, you won't get the incredible sound you're looking for.
I'm not trying to discourage you, it's just that these things take time.
Thanks. The Echo is on its way back. I am getting wood the more I read about the R16, from a drummers standpoint I'm not sure if it gets much better in that price range (please correct me if I'm wrong!), seems like a quality device. I'm pretty sure that thing works with Pro tools?
Cool thanks for the info. I think I'm going to jump on the R16. I also heard good things about the Audix mic's I got, we'll see how it goes!Yup. The R16 is a darn good mixer for the money (Allen and Heath don't make bad mixers). My only quibble is the 60mm faders...I'd have preferred 100mm like the Mix Wiz but even Midas made the Venice with 60mm faders.
Yes, it'll work with Protools. You'll have to do some manual setting up and you'll need the MIDI to HUI converter that you can download from the A&H site HERE. The same URL also has the set up manual for using the mixer as a control surface with Pro Tools so you can check on software versions etc.
As for your mics, I'm a fan of the Audix drum kits. You can gradually start to mix and match other mics as you like (yeah, start with the overheads) but the D6 is my favourite kick mic even when I use other things elsewhere.
Does that mean the OP is inept or that anyone could give you pointers, even someone who is inept ?Hey OP, could you list all the mics you are using, and what drums they are on? I was looking to expand my drum miking capability, and I think someone who is inept at doing it could give me a few pointers,
