alright, i've got about a thousand questions, so i apologize in advance. first of all, is there a way i can adjust the level my daw itself records at? this probably isn't even relevant considering that even though the clipping sounds digital (right?), it still occurs even when my waveform is practically flat - if it were distorting at the digital conversion, wouldn't the wave basically be a spiky block? i assume this is why you've been suggesting i adjust pre-A/D settings.
Ok. Look at the levels you're getting on the mixer with those mics (hopefully you have peak reading meters in the mixer for the pre/channel (..and main out if you're using it and not going channel direct out-) Are they ok there?
Or, set up a test- anything other than those mics, that will give you similar levels in. Is it clean then?
Just per chance- what's you're location?
i don't think the signal is clipping at the pre because i'll still hear distortion when i record with the gain pot barely a hair above zero. there wasn't really any correlation between how much clipping occurred and where the gain pot was - the signal distorted about the same regardless of volume. but just to be sure, if i were to set up the mixer so i can see it while banging on the drums, would this be a decent way to check levels?
and if i do find clipping, then what? lower the gain pot until the peak indicator doesn't light up, right? is there any point at which i should screw around with the faders? i figure (in the case that the signal is clipping at the preamp) i'd try to get the signal down to where it isn't clipping, but since i'm hardly getting a waveform on my daw, i would switch the delta from +4 down to -10 in order to compensate. does that sound about right?
i'm skeptical that this won't work since i've consistently gotten distortion even when the gain is at next to nothing. i'll try anything though!
LASTLY, i was thinking i would test out the mics on something quiet like an unplugged guitar. if i adjust the gain to get a decent signal and find no distortion, that would point to the issue being the spl handling. if there's still clipping, then that would narrow it down, right?
and i'm currently located in western massachusetts. thanks a lot for all your help, i can't tell you how much i appreciate it.
What mics did you use before that didn't give you any problems?
a couple of ten dollar nady dynamics
Which mixer outputs are you using to get the signal from the mixer to the Delta? If you're not using the Inserts then you could bypass the faders & eq on the mixer by using the inserts.
the snare & kick are going through the main xlr outputs. the overheads are going through a second bus, 'alt 3-4'. here's what the back of my mixer looks like:
http://www.ology.net/blogs/music/1204_rear.jpg. would bypassing the faders/eq theoretically be beneficial for my situation?
