C
connor413
i picked up a pair of behringer C2s about a month ago and i've been having a lot of trouble setting up the gain staging for them. no matter what i've done so far, i can't get em to stop clipping - most likely at the point of conversion from analog to digital (i think).
this is my chain:
C2s > xenyx 1202 mixer > m-audio delta 44 > daw
and there are a few points where i can adjust the signal:
-trim / gain pot for each input
-fader for each input
-master fader for the particular bus these mics are going to
-the delta 44 can be configured to -10, consumer level, or +4
the mics themselves also have a -10 pad which i have switched on.
i've tried lowering the master fader (to try and cool down the signal when it hits the delta) while boosting each track's own fader in order to compensate, but this basically just raises the noise floor as the master fader goes down. i've tried leaving the master fader at 0 and adjusting the trim pot and/or individual track faders, but there's still clipping occurring. i've also tried switching between -10, consumer, and +4 on the delta, but that didn't solve the problem either. if anyone has any ideas that might help, i'd really appreciate it.
the mics are set up in the glyn johns configuration if that has any bearing on this
this is my chain:
) could just as easily be completely on the wrong path. Bad drivers, format? Just that I went through the Mackie bad ribbon thing.
