The problem you got there is a corrupt driver. I had the same problem with my MIDI controller. I did the stupid thing though & started editing my registry to try to delete the corrupt key. I ended up bricking my HDD. Good thing all my data's on a different HDD.
Anyway, what you want to do here is download the newest driver and the one just previous to that (in case there's something wrong at the core of the newest one). Then go to device manager, right click your audio & click update driver software. Select browse for my driver software & locate that newest driver you just downloaded. Let the system do its thing, restart & see if that fixes it. If not, the new driver is to blame, so you'll need to repeat the steps above & find the one previous driver that you also downloaded and use it. If that doesn't work, then it's another
Windows driver & you'll have to find which one & reinstall it.
I hope that helps. Whatever you do, don't try the regedit option unless you're absolutely sure you know what you're doing. I was absolutely sure & still screwed it up. Oh, and don't forget to back up everything before you try.
Cheers!
