Drive check on VS880
Tweedville
When you use drive check on the VS880,is it checking the drive itself or the disc in the drive? I am using an external drive (ORB)and it started acting up,so I did a drive check and found errors......is it the ORB disc or drive itself?
Thanks,
The Tweedster
Thanks for your reply,chapstick.
The VS880 doesn't have a drive in it right now...plus I set the drive check for the ORB,which is the only drive hooked up.
