DP 24 Effects 2, question.
  • Thread starter Thread starter wawhoudini
W
wawhoudini
I've had the DP 24 for about a month. Everything works great and it is very intuitive and easy to understand, accept one thing. Is it possible to send two effects to the same track? For instance, can I record a vocal track and add both reverb and delay to that one track? I see there are 2 effect send knobs but have been unable to figure out how to get the second one to work. If I can't add 2 effects to the same track can I duplicate the track and send reverb to the original and delay to the duplicated track? Any help would be greatly appreciated.
No, you can't do that internally, only one internal FX processor ... but the 2nd send is for an external FX processor. You could do as you say, I don't know what your result might be, but it's worth a try. I'd record the dry track, and then assign your effect and route to an unused track, assign 2nd effect and route to unused track. Then mix. Otherwise you'd get reverb on your delay, or a delay on your reverb.
