Download Tracks and Mix For Fun - *** Round 2 ***
  • Thread starter Thread starter NL5
Stuif said:
Well, 3 hours playing with the tracks, as they are came, resulted in this:
Killing you softly
What ya think?
Overall I liked it. The third track of vocals show be lower in the mix and should only be during the "Killing You" part of the song. ALso the "Im am" in-between the Killing You should be a bit lower as it is more of a back up vocal. The deeper vocal should be more previlent.
I think if the vocal tracks were edited/mixed as mentioned above it would be great.
No matter what, thank you for taking the time to listen and mix the song.
Peter
SuperGeek said:
To Bloodsoaked
Here is the first one, it was done with headphones. :p
The next one will be done without. :D
Just hope i did not kill it to much :eek: :eek: :eek: :eek:
Killing You
Thanks for the chance :D BCD
I would love to hear a version were it was all in time as I just loved the guitars.
Peter
Killing you softly
What ya think?
At least now I know the song can be edited and mixed with the files that are online since you were able to mix it.
Peter
Hi Peter,
I imported all the supplied tracks into Sonar 5 at 00:00:00
They are not synchronized but I found it relatively simple to start bringing things back into line.
The 4 guitar tracks and single bass line I left at 00:00:00
I then clipped the beginning of the drum track to eliminate the count in and then dragged it into the correct position to suit the guitars and bass. To halp me double check that I had it right I also imported the finished mastered track.
All I need to do now is line up the vocals and then I can start to play around with it. Ran out of time last night so perhaps tonight I can do some more.
cheers
andy
Peter
That's what took quite a part of the 3 hours I spend I guess.. Most of the tracks had to be re-aligned. I wanted to tell in this topic on what point I placed each track (time-wise), but forgot to do that.. maybe later today, when I'm home again.
I will also look into that vocals issue.. To be honset I only used 3 of the vocal tracks + backing.. less=more sometimes (at least quicker ;) ).
I used the mp3 you posted in the mixing/mastering section of this forum as a reference where to place the tracks.
Synkrotron said:
Hi Peter,
cheers
andy
Cool! Sorry that my files were not perfect but as long as you can work with then that is great. I will be interested in hearing what you come up with. Thank you...
Peter
Ok, cool. I guess mix it anyway you think sounds good. This is a experiment for everyone. Something I think sounds good now might sound even better than I thought it could.
Peter
Was this done with a drum machine?
If so..whats the BPM (beats per minute) ????
Yes, it was done with a drum machine. I am at work now but I beleive it was 190bpm and the "Killing You" part was at 180. I think the whole song was 190 besides that. I can look when I get home if you need to knwo for sure?
Peter
Bloodsoaked said:
I just downloaded the file and the whole song if off timing. The drums start all alone adn then the guitar kicks in and then the back up vocals. The song is all over the place.
Besides that from what I could make out I love the guitar sound.
You might want to check out the mix again.
Peter
Thanks for the info
what are the start times for each track and i can make the adjustments I will play with start times for now
Barry
SuperGeek said:
Thanks for the info
Barry
For me each of the tracks start at 0. You might need to adjust them in your program.
Peter
Hmmm... I'm not that happy with what I've done... I suppose I could have come up with a load of smart arse excuses...
s'pose I should revisit it a few days from now... seems it's what the experts say.
anyways... here's my first attempt :-
Killing You SFU Mix
I've used all four guitar tracks and I've panned them as follows:-
100% Left - 50% Left <> 50% Right - 100% right
Don't ask why.. I just thought I'd try it.
I've used a compression plugin on the bass although I suppose it was pretty much compressed anyway.
I used multiband compression on the drums and I thought it helped to bring up the kick a bit more.
I experimented with the panning of the vocals with one panned centre and the others panned to varying degrees to the left and right.
As I said, I'd like to come back to it in a weeks time and have another go.
andy
Killing You SFU Mix
andy
Very nice job dude! I guess the only think I would change would be to lower the screemed vocal track as that seems to be cutting through to much. I think the mix is really good. I like the bass cutting through a bit more than in my mix. Let me know if you give it another try in a week.
Peter
Peter
Thanks Peter,
I've just had a listen at work and I was worried that it might be a little bit to bassy. I'm going to cue up all the other versions I've collected from here and see how mine sits with those.
I'll definitely have another go. Last night it took me quite a while to suss out the vocal track song positions so my ears may have been getting a bit "tired". I'll take on board you comments regarding the vocals. To be honest, I ended up ruching it out and wasn't too sure which of the vocal tracks were intended to be the "main" track and which were "backing". You have one vocal low and two vocal high (from what I remember from last night - my memeory really is that bad) and they finish half way through the song. Once they've finished I used the other three tracks but I think (they were not labled as vocal tracks like the others) that there were two low vocals and one high. So I wasn't sure what to do.
cheers
andy
Synkrotron said:
Thanks Peter,
cheers
andy
The deep vocal tracks should go through the whole song. I think you are correct that they got split up. try and have the deep vocals for the whole song and the higher vocals only for the "Killing "You" part. So cut out the higher vocals eacept for the killing you part and the other back up tracks should sit good. If you want any other into let me know and good luck.
Peter
iwant tomixing some tracks of death metal im toobored but the link marks me error please somebody sends me the tracks for posting my work
I'm not surprised that you got an error considering this thread is just shy of 5 yrs. old. :eek::)
