doubling vocals
  • Thread starter Thread starter lopie
Maybe I Can Help
What You call doubling in the south we call it stacking so when I say Stack that's what I'm talkin about. A good way to make it full when you stack is to do your lead (The Main Vocal) and then stack it and what you do is have your lead volume (I use cool edit 2.0) at let's say it sounds good with the beat at around -2.0 db then turn your stack down to about -10 db or just turn it down low enough to where it's not to loud but you can tell it's there that will give you the fullness that I believe you are looking for
4 vocals
I'm currently working on a song which I am putting some of these techniques to use on.
In addition to the main vocal I have recorded a monotone heavily compressed whisper, a high pitch version of the lead (same notes higher octave) and a double of the lead but lower in the mix as suggested in the previous post.
Gettin the righht blend can be tricky, but it seems to work really well in getting the vocal more powerful and clearer.
The only difficulty is theose word ends, if you don't finish all the lines spot on then it's noticeable with like and echo as each line finishes a millisecond or two after the other, most annoying. Also it seems to boost the 'SSS' sound too much. I don't have a de-esser ;-(
