MadAudio
Damned if I do
well heres a clip of some raw drums i recorded
never seems to sound the same mixed down as in cubase tho![]()
Are you mixing directly to mp3? That could be why.
Absilutely, I agree with experimentation. But again, mixing 2 identical kik drum sounds that come from the same mic, drum, and recording does nothing other than make the kik louder. Your technique of mixing DIFFERENT bass drums is legitimate.
i do completely agree with getting the best raw sound possible
my problem is i dont know what to look for in completely raw drum sounds as im so new to the game.
so what ill try do tomorrow or the next day is record a little test on my kit, completely raw no eq or compression or reverbs or anything, and ill try get it posted up here so you guys can hopefully tell me if im doing anything right or anything wrong.
id be very grateful
oh and does any one know a good site i could host the mp3 on?
Maybe it was in his other "drum delay" thread.Obviously I missed something because I don't see that info anywhere in this thread.
Because I have real drums, enjoy playing them, enjoy recording them, and enjoy the results. I also use mediocre stuff in a not-so-great room and get pretty good results, so I don't accept giving up and switching to samples.It is pretty common, my guess would be over 50%. But that's another discussion. I never said he should use samples I never said that doubling the kick is the right thing for him to do. I said it might work for him depending on the sound he is going for.
My only point is that it IS a legitimate technique and you can get some really cool results with it. Honestly try it and see. Isn't that half the fun? Messing around and trying different things? If you are happy with the end result why does it matter what path you took?
I don't knock people using samples if they have to. This cat has real drums and mics though. I feel that he should learn how to record them.
im not boosting an insane amount, about 1.5 to 2 db boost in the 90 - 125 range
Why do you keep saying this? Who said give up and switch to samples?I don't accept giving up and switching to samples.
Abslutely, I agree with experimentation. But again, mixing 2 identical kik drum sounds that come from the same mic, drum, and recording does nothing other than make the kik louder. Your technique of mixing DIFFERENT bass drums is legitimate.
BINGO!!!...
If you take 2 copies of the same wave and EQ them differently you're really just EQing ONE sound. You're elevating the same frequencies as if they were the same track.
If you take two identical waves and play them both at the same volume,then you EQ out some of the frequencies in one wave - nothing will happen to the sound!
eqing the tracks differently to get lows on the one and the 1 - 1.5k attack region on the other
That's all I need to know.i duno, ive just tried it and it seems to make a huge difference
Because it's the exact same thing as turning up the attack on ONE TRACK. Why is it so hard for you to understand this????I agree with both of your statements. But that is not what I'm talking about and that is not what he is doing.
He is :
Sometimes if you raise the volume of a kik drum to much it muddies the mix correct?
You could fix that by cutting some of the low end on the kick and the bass right?
What if when you cut the low end of the kik it sounds like crap?
Do you just boost the hell out of the mids and highs?
Maybe it would make sense to double up the kick track, cut the low end off one of the tracks, and raise the volume on that track so you raise volume of the attack without raising the volume of the boom?
When you double guitar tracks you PLAY THE TRACK TWICE. It's not the same as copying and pasting it to another track. If you copied and pasted a guitar or vocal track to another track, it would simply make it louder, just like we've been trying to tell you the same thing happens with a bass drum.Isn't it common to double track guitars and vocals? Why dose it sound so crazy to you guys to do the same with a kick drum?
What part of his quote is supposed to convince us? The "I dunno", or the "It seems"???But most importantly this: "I dunno...It seems to work for me".
No one. I was just making a point. Why fuck with samples when he has real drums?Why do you keep saying this? Who said give up and switch to samples?
It's not the same. Double-tracking is playing the part twice usually for a thicker or more full effect. Thats 2 different takes. He's not recording another kick track. He's just duplicating the existing one. Not necessary. Truly double-tracking a kick would be retarded.Isn't it common to double track guitars and vocals? Why dose it sound so crazy to you guys to do the same with a kick drum?
If it's the same then why is it so wrong? lol I actually agree though it is pretty much the same, more than one way to skin a cat ya know?Because it's the exact same thing as turning up the attack on ONE TRACK. Why is it so hard for you to understand this????
I didn't quote you saying you tried it because you didn't use eq and honestly how much effort did you put into it? If you told him to try some different mic placements and he came back 15 min later and said OK I moved the mic and it didn't work what would you say to him?Funny that you didn't quote me saying I tried it and it made absolutely no difference. Because I know it doesn't.
That's always the best way to go into an experiment, already convinced of the results.I tried it and it made absolutely no difference. Because I know it doesn't.
Why don't you guys get phone numbers and take it in turn to post?
So 2 pages into the thread you finally agree with what you've been trying to to disagree with for nothing???If it's the same then why is it so wrong? lol I actually agree though it is pretty much the same, more than one way to skin a cat ya know?
You just admitted it doesn't work. You're starting to foolishly contradict yourself. And once again, and I'll type slowly this time.....You're "accomplishing" the exact same thing as you would by having one track at the same volume as the 2 combined. But you already said you know that.I know that double tracking usually involves playing it twice my point is you can have two mostly identical tracks and not have it to loud.
Nowhere did he say "I doubled the tracks and kept them both at the same level" therefore doubling the volume. You definitely need to turn both tracks down significantly to make this work.
Are you really typing any of this with a straight face???? If it takes you hours to copy a track, turn one up, then mute one, and you compare that with how long it takes to mic drums, then that explains alot about your "theories". But you already admitted there was no difference, so why are you questioning my results??? Once again, contradiction.I didn't quote you saying you tried it because you didn't use eq and honestly how much effort did you put into it? If you told him to try some different mic placements and he came back 15 min later and said OK I moved the mic and it didn't work what would you say to him?
Seems to me you would have only been happy if I said you were right. Turns out you ended up saying we were right all aong....but you're still not happy for some reason. That's really odd.That's always the best way to go into an experiment, already convinced of the results.![]()
....oooofffff......
That's enough for me.....At this point, we'll all just be repeating ourselves.
