E
Ephi82
I can't speak specifically to the Doors show, I don't know what the specific plan was there. But you're right, double miking the live vocals was something you'd see a bit back in the 60s. I remember seeing a Sam and Dave set up with dual mics for each, simply taped together one on top of the other, for example.
Sometimes I think that was done like Steenaroo said, in order to blend the sound of two different-sound mics and/or preamps. Sometimes it was an even simpler reason than that; doubling the signal allowed them to stack the tracks and get a bit more additive volume in a live setup when competing against live amplified instruments without having to crank a perhaps noisy 60s PA channel or mixer with lots of stage bleed. When you consider that neither Jim Morrison nor Sam and Dave were exactly headbanging screamers, that might not have been such a bad idea.
But when it comes to actually fattening up a vocal's sound, double-tracking or chorusing or parallel compression are probably the ways to go.
G.
Boy I'm getting old! The technique of having two mics on stage for each singer, physically taped together was done to feed two sound systems. One for front of house, and the second for stage monitors. The boards in those days did not allow for monitor sends!
Nothing sounds better than a good singer truly double tracking a vocal! That's why the pre ADT Beatles vocals are so kick ass, and why they returned to that technique for their final masterwork, Abbey Road. Listen to "Because", three vocalists, triple tracked.......Try it at home.....the lush beefy vocal sound you get is worth the effort and practice. By the way, the practice will also help you become a better singer. Rock on!
