eyema_believer
Bondservant
I am constantly bombarded by emails offering to help me enhance my dongle, but never to replace it outright....
HA!!
That's the funniest thing I've heard all day
Some people complain that the dongle "needlessly" takes up a USB port. Others have said that the constant checking Cubase does to make sure the dongle is still there affects performance (if not stability). I don't know how much truth there is to the latter claim, but it wouldn't surprise me if it were true. I'd be interested to know the results if anyone has run a legit copy beside a pirated copy.
That's an excellent point. I think this was more an issue for people years ago when motherboards only had 2 USB ports (and none front-side). So while, sure, they could get a USB hub, I can see why it might be considered a minor pain.To those people, I would say that they should learn about how USB works before complaining about "wasting a port". You can connect 127 devices (in serial, hence the name, Universal SERIAL Bus) with any single USB controller (even if that controller only has a single USB port). The entire architecture was designed to allow connection of multiple devices through one port so this complaint is uninformed and really....it's just silly.
Ah, I see. But I'd be surprised if a USB "heartbeat" was as fast as a software one. Though granted, I don't know enough to say this with certainty.The altered versions don't even remove these checks - the dongle is just emulated in software and all those calls are still made (to the emulated dongle instead of a physical one) - so again, this is just silly.
Oh, and I've read complaints on cubase.net from people who want to use Cubase on a laptop. Few USB ports = dongle annoyance.That's an excellent point. I think this was more an issue for people years ago when motherboards only had 2 USB ports (and none front-side). So while, sure, they could get a USB hub, I can see why it might be considered a minor pain.
That, and if they want to use it in a live setting, there's always the danger of the dongle getting lost/stolen/broken.
It is a lot easier to lose a dongle than a snare drum. I have a USB key in front of me that I have to drop in a colleagues letter box in the morning because he left it behind. Not the first time I have seen USB keys lost. Right or wrong we are only human and it happens. These things have a tendency to get lost.Again, if you lost a $600 snare drum, can you call up Ludwig and get them to send you a new one?
OK, not a snare drum but one of those little $300 iPods, will Apple replace it because you lost it?It is a lot easier to lose a dongle than a snare drum. I have a USB key in front of me that I have to drop in a colleagues letter box in the morning because he left it behind. Not the first time I have seen USB keys lost. Right or wrong we are only human and it happens. These things have a tendency to get lost.
I guess that the dongle method of securing software must be the most secure method. Otherwise it would be a no brainer that you would include the security system in the software.
BTW I downloaded Reaper for a trial. I've never used anything digital in my music life. It has a free 30 day trial so I thought why not give it a try. Seems quite good to me and I am told it has no technical limitations. Any comments?
Good point, your logic is sound. I counter your parry with;
Can a protection mechanism built into the software be as effective as a dongle system?
I checked Reaper out, it seems good and the price is great. But I know very little about this stuff. Can anyone think of a disadvantage associated with a newb becoming committed to Reaper rather than Cubase? I don't want to have to re-learn everything in 3 years if someday I find I started out on the wrong track (product). I am guessing it takes a long time to get deep understanding of a sequencer when you start from a base knowledge of zero. I don't want to do it twiceGo to www.reaper.fm and get a sequencer that doesn't require one (and is cheaper than Cubase, too...)
No! A lot of us (well... me, at least) would LOVE to be in that position - Instead, I am totally locked into Cubase now - it would take so much time to switch over to Reaper with all the templates, presets, drum maps, etc. etc. etc. etc. I have spent countless hours building in Cubase that I now rely heavily on to work efficiently. From what I have read and heard, there isn't much, if anything at all, that makes Reaper inferior to anything else, and there are quite a few things that could arguably make it superior. I was fascinated with the plugin scripting system, personally... never seen anything like that - scripting your own plugins=Brilliant!
Wait... what? Really? Who told you this, and why did they say it was the case? I don't think this is correct at all - as I have always understood it, the fundamental way that Firewire works is just better for constant streams of information like is needed when doing A/D conversion in real time - you can't afford to just drop bits here and there or you get nasty artifacts/sync problems. USB, however, does not share the same...foundation (for lack of a better term) and is more prone to the afore-mentioned issues. If this is not correct, then I want to know. I could go research it, and I probably will - it has something to do with asynchronous transfers (or something to that effect), if I recall correctly...Great. I can spend a bit extra on an interface (Edirol UA25EX USB was recommended. I thought should go Firewire but not needed and can create more hassles I am told)
If I go Cubase I am guessing with the dongle system I could have Cubase installed on any number of machines simultaneously, carry my dongle with me and plug it in to use a machine. Is this correct?
