C
chrisbc
I've discovered (after many hours of fiddling) that my SCSI reliability problems were actually caused by the main IDE hard drive!!
I set up this poll to see if this helps others with similar problems
Typical symptoms:
- Fostex doesn't recognise format of SCSI device.
- Backups work, but restored wav files are all 'hiss an cracks'.
- Wav files are corrupted - PC (or MAC) software can't read them. BTW there's a workaround for this.
- Can't transfer wav files form PC to Fostex.
- Fostex corrupts the FAT format, chkdsk reports errors.
I had all of these problems, and it seems many others have too, with various model of Fostex HD recorders esp. D series and maybe V series too.
I tried many things, including JAZ drives, External SCSI HD and SCSI ZIP. All were very unreliable on Fostex, yet worked fine with the PC. I tried different cables etc, etc, with no joy (and many wasted hours)
I started to think that my D1624 SCSI interface was totally %$!!ed. Then, I decided to try again, using lower sampling rates to minimise load on the SCSI. I picked up a spare 6.4GB hard drive and formatted it in my Fostex. Huh - it works!! I try a several different formats including 96Khz, 24 bit and it still works 100%. I put my 20GB (Samsung) disk back in, reformatted it and, yep the SCSI is once again stuffed.
Incidentally, the Samsung SV2001H IDE drive was installed by the NZ service agent for the original owner of my unit. It worked fine for everday recording purposes.
SCSI devices that are now working fine...
- IOMega 1GB Jaz disk in 2Gb drive
- IOMega 100MB Zip Plus (SCSI/Parallel)
- IBM DCAS-34330 4GB hard-drive.
After all the hassles I almost can't believe it
The IDE drive that works well is a Fujitsu MPE3064AT 6.4GB unit. If you find the same issue with other IDE drives, please post the details here (including whether it was good or bad).
Typical symptoms:
.I started to think that my D1624 SCSI interface was totally %$!!ed. Then, I decided to try again, using lower sampling rates to minimise load on the SCSI. I picked up a spare 6.4GB hard drive and formatted it in my Fostex. Huh - it works!! I try a several different formats including 96Khz, 24 bit and it still works 100%. I put my 20GB (Samsung) disk back in, reformatted it and, yep the SCSI is once again stuffed.
