Seafroggys
Not curtains. You need mass.
My Esmono booths use 50mm, but the later ones upgraded to 80m.Rockwool is great - but look how much depth people use - 50mm/2" is absolute minimum
damn. Can u show me curtains that are t hick aenough>?
I have TWO!You have one raymond?
You are not paying attention to the replies - acoustically your room is a disaster - way to junky - why is there a lamp on the floor? Putting up drapery with the intent of ‘fixing’ audio problems is a fools errand - you don’t know what is a problem in the room to begin with.Do I need to treat this corner? Because there is a cupboard inbtw the sound wouldnt directly go there so I thought maybe I dont have to treat it.
no i meant to say vocal booths or what they r called, the small rooms where opeople record in, for voice over, theose very small ones where it's just u and the mic and ur laptopSmall tubes? If you mean those vocalshields that are popular, they're just foam so good if the rear of the mic picks up reflections from a wall - they help, but again, foam only works higher up. I've got one, and they are just a bit odd to work with. My studios aren't a problem.
So they don't make it boxy if this is what you are thinking, but a tube? Not really sure what you mean. Have you an image?
They are quite oppressive to work in - the image on the right is better - but that screen is a non no - reflective and spoils everything the tiles do? The left ones is like the tiny spaces in outside broadcast truck - they sound very strange and mixes you do translate very differently to what you imagine. Very narrow speaker spacing, little real bass and the deadness all make it necessary to have a good knowledge of how to mix when you can't hear properly. For speech? Probably OK. Square tubes? A bit like a spherical pyramid he he.
