cordura21
If you multi-compress is it better to compress harder on the low part, or the reverse?
Cheers, Andrés
Cheers, Andrés
No, not primarily, though this is a factor.cordura21 said:thanks, I think it has to be in part cause of the Fletcher Munson effect, right?
No, the first order principle is that loudness perception is essentially an intensity (energy/time/area) perception rather than just an amplitude perception. This directly addresses the question of why bass frequencies take up more headroom than high frequencies. This is also why pink noise sounds much more spectrally balanced than white noise. Pink noise has a flat intensity spectrum.Creepy said:barefoot, what you just described IS what the relative loudness curve is all about.
Yes and no. Bass frequencies are always going to eat up most of your dynamic range if you want your music to sound like…well.. music. It’s just a fact of the principles of loudness we discussed. On the other hand the largest short duration peaks tend to come from kick drums for which the bulk of the signal lies in the low frequencies. So compressing the lows will tend to smooth out the large peaks more than compression in other bands. Of course you can use a single band compressor or a limiter to smooth out large peaks as well. Sorry, there are really no hard fast rules. A lot of it comes down to what sound and feel you’re aiming for.cordura21 said:.....it's better to compress bass so the amplitudes are not so highs, yet the rms or average signal is less dynamic and more constant. In this way, the bass is there yet it doesn't it all your headroom....
Absolutely. Speakers have really horrible levels of distortion compared to everything else – especially in the low frequencies, and especially for ported or passive radiator (like Mackies) speakers working below their tuning frequencies. If you’re trying to make a 6” or 8” driver output any significant amount of energy below, say 60 Hz, I guaranty that you are creating truck loads of distortion – upwards of 10% or even 20%.littledog said:...if recorded material has a high level of sub-sonic content, in the struggle to reproduce those tones, will the typical speaker driver end up distorting frequencies that are higher and more easily audible?....
i've played 33hz through 8's.. they weren't distorting at all..barefoot said:Speakers have really horrible levels of distortion compared to everything else – especially in the low frequencies, and especially for ported or passive radiator (like Mackies) speakers working below their tuning frequencies. If you’re trying to make a 6” or 8” driver output any significant amount of energy below, say 60 Hz, I guaranty that you are creating truck loads of distortion – upwards of 10% or even 20%.
Well, then the volume was either very low, or you don’t know what a pure 33Hz tone sounds like. And I’m not being condescending. Most people don’t have any experience at all with unadulterated deep bass, unless perhaps they’ve heard it through good headphones. I have little doubt that at normal volume you were listening to at least 10% distortion.c9-2001 said:i've played 33hz through 8's.. they weren't distorting at all..
even while mixing..i don't have any problems with distortion through 6”. i don't have 1 song that doesn't have a lot of low bass.. i have tracks that go down to 18hz...
no problems with distortion at all..
barefoot said:Well, then the volume was either very low, or you don’t know what a pure 33Hz tone sounds like. And I’m not being condescending. Most people don’t have any experience at all with unadulterated deep bass, unless perhaps they’ve heard it through good headphones. I have little doubt that at normal volume you were listening to at least 10% distortion.
I’ve had success getting less than 1% distortion at reasonable listening levels in medium sized rooms with pairs very sophisticated, very expensive 18" drivers in "quasi-passive" configurations. You can get away with smaller drivers using active feedback techniques like those used in Velodyne subs.
barefoot
Recording the signals isn't the problem - reproducing them accurately is.c9-2001 said:yes i know what 33hz sounds like... i build custom stereo system with the best quality products, that usually pick up down to 25hz...
i can send you a quick sample of a song that goes down to 18hz.. the 6"s just just about reach peak xmax at high level, they can't pick up 18hz.....
