I am not "Delusional", I am an "Artist". I am not going to run out of tracks, I have 4 TSR-8's, an MS-16 and an MSR-24. I have a couple of Tascam synchronizers too if I need to link up some machines. BTW have you ever heard of mixing multiple microphones to any number of tracks using "Sub-groups"? Do you think the "Dark Side Of The Moon"( or "Sgt Pepper") sounds better in the "Abbey Roads" tracking rooms than it does on virgin Vinyl? I wonder who is "Delusional"?
VP
Well, you've pretty much said it right there, people who want to emulate approximately 15 years of rock recordings like tape, most other people don't . . . I will tell you one thing, the end of "A Day in the Life" doesn't sound anywhere near as good as a live orchestra playing the same part; if the rock musicians have the same amount of talent (which many do), then the whole shebang can be done live and it sounds much better than Memorex (or Tascam).  Sorry.
			If you look again you can see the word "Accurate" is absent from the OP post. Please stay on topic.
Wrong, OP asked an objective, comparative question about analog vs. digital that is verifiable via experimentation.  It did need some interpretation; I take "moves more air" as "accurate LF response".  That is somewhat open to conjecture, but whatever the definition, it's not a subjective artistic question.
I propose the following experiment:  using a calibrated, flat-response measurement microphone, a 1kHz test tone is recorded direct to digital and also direct to cassette (OP mentioned cassette, not 2", not 1/4") with digital level set at -12dBFS RMS and tape at 0dBVU; a close-miced kick drum is recorded at the same matched level such that the peak of the kick drum be the same level as the 1kHz tone.  Playback of the two sources is again direct from source, with the volume of 1kHz test tone matched between sources, and initially set to represent a similar SPL as would be experienced at the same distance from the kick drum (as measured with a fast-response C-weighted SPL meter).
A candle shall be placed 10cm from the middle (measured along its radius) of a 25cm diameter low-distortion woofer, with a ruler placed to the side of the candle, and a camera on the other side, such that the deflection of the candle may be recorded.  There shall be no material deflection of the candle from any ambient air movement.  If the candle is extinguished by the kick drum from either tape or digital source, then the experiment will be repeated with volume reduced in 3dB steps until the candle is not extinguished by either source; the results up until that point shall also be noted.
The resulting deflection from the kick drum hit shall be measured and compared.
Sound good?  Will that settle this debate?  If so, I'll take care of it
				Ato said:
			thirty years after tape recording was developed, were people trying to find a way to make it sound like a wire recording?
I don't use tape emulators, sorry, they don't interest me.  I use a touch of generic EQ and a little bit of a compression algo I wrote that can also do a bit of saturation if I want--but that emulates transformers and single-ended tube circuits, not tape.  And I have real transformers and tubes laying around if I really wanted to build the analog circuits, but I don't use the emulation that much so there is no real need for the real thing either.  If I'm doing a rock recording I use a bit of UAD plate, I do like that.  I use a guitar effects simulator because I don't use amps anymore, although someday I might rebuild the amp I built, right now it sits in the shed unused and unloved
  There are lots of things that simulators can do that are very hard to impossible with amps anyway . . . Bass I've always recorded direct with no effects, I think they used to do that back in the '60s too . . . but I really wish I had a standup . . . touch of compression, maybe 2-3dB, and bass is done.
Otherwise, it's microphones and acoustic instruments, that gets the job done.
