A
ad0lescnts
so hostile...cant we just be uncivilized?
tyler657recpro said:You couldn't be more wrong, but you can think what you want to think, and anyway it's beside the point. Behringer patchbays suck. That's all I'm trying to say, and you drag it out into all this and waste people's time. You don't have a fucking clue and you seem a little imature to be 36, but you probably really are. By the way, a lot of the shit in your stuido is crap. Especially that Mackie console. Nobody pays $3500 bucks for a recording console. I'm not dissing makcie, but that particular mixer is a piece of shit. And you call yourself a recording engineer.
VOXVENDOR said:Talking sense into this kid is almost as hard as trying to drag a brutha into a starbucks....
(MrQ, im sure you know what I mean)![]()
tyler675recpro said:I love patchbays, they dont degrade the sound. Just dont buy the behringer! They made a major design flaw, and wired it out of phase!!!! Can you believe it!? So if you ever get any cancellation, you'll know why.
toby.I. said:ignore that, didn't read any of the above! Is it a Mackie 8 bus blue bear has?
sjjohnston said:Not that it matters much, but someone might be reading this thread thinking it contains some information ....
An unbalanced patchbay can't be "out of phase" (by which, I think the original poster intended to refer to reversed polarity to be completely correct). If you connect tip to sleeve, you don't get a reversed-polarity signal, you get no signal at all. The sleeve is connected to ground. If you connect your signal line to ground, it will never make it to where it is supposed to be going. Take a look at a 1/4" connector (or an RCA connector, where it's even more obvious) and look at how the sleeve is connected.
You can invert the polarity of a balanced line, simply by connecting tip to ring, and ring to tip. Depending on what's connected to either end of the line, this could produce a reverse-polarity signal.
(As one writer pointed out, the above doesn't apply if you are connecting speakers to an amplifier, which is an entirely different setup from connecting signal processors, mixers and the like through a patchbay. Does anybody connect speakers to an amplifier through a patchbay intended for line level signals? .... If they do, they should stop.)
Bdgr said:... For instance, a drum machine running off of a wall wart plugged into your computer in. These devices do not share a common ground, and since AC swings from positive to negative and back again, making the ground the signal and the signal the ground make no differance whatsover(other than being out of phase)....
ad0lescnts said:what the hell is a patchbay anyway?? i know what they look like and shit.. but.. i guess i found myself reading your guys' silly arguments rather than the discussion itself!
