D
djclueveli
i bought a presonus firepod today. my question is is my presonus now my sound card? and do i uninstall the sound blaster audigy after installing the presonus?
studiomaster said:it's gonna create conflicts...personally, i rather not put them running together.
Traditionally, you'd build a small, controlled fire (Safety First!) somewhere with a decent amount of space. Then, a ritualistic dance would follow as the parts (the installation disc, any connectors, followed up by the card itself) are cast into the flames one by one. You can have someone read a verse or two from the Mixerman Diaries between each burn (that's optional, but many find it enlightening during the ceremony).do i uninstall my soundblaster after installing the presonus firepod?
Massive Master said:Traditionally, you'd build a small, controlled fire (Safety First!) somewhere with a decent amount of space. Then, a ritualistic dance would follow as the parts (the installation disc, any connectors, followed up by the card itself) are cast into the flames one by one. You can have someone read a verse or two from the Mixerman Diaries between each burn (that's optional, but many find it enlightening during the ceremony).
Whenever opening a new studio space, one should steal a brand new Soundblaster from Circuit City that has never has never been out of the box and never had any juice run through it - i.e. a virgin card - and perform the Massive Ritual to appease the Gods of Audio.Massive Master said:Traditionally, you'd build a small, controlled fire (Safety First!) somewhere with a decent amount of space. Then, a ritualistic dance would follow as the parts (the installation disc, any connectors, followed up by the card itself) are cast into the flames one by one. You can have someone read a verse or two from the Mixerman Diaries between each burn (that's optional, but many find it enlightening during the ceremony).
Most of us are referring to the PCI or on-board cards that come standard with PCs.sjfoote said:My Audigy SE records at 24bit and 48kHz, worked first time after installation, plays fine with ASIO4ALL, allows me to use professional SoundFonts, works with CakeWalk MC3, and sounds a lot better than the digital 4-track I was using before.
Studio quality - no.
Home-recording level quality with no learning curve - yes.
foote,sjfoote said:To me, this is what makes hobby-level home recording within the reach of so many people. That's why I defend the often bashed SoundBlaster and low cost software route....
sjfoote said:Sure are a lot of SoundBlaster haters....
