ashcat_lt
There isn't any ground loop between the bass and the mixer. Can't be. The buzz comes from the fact that it's a single coil pickup. You could try shielding the cavities in the bass with aluminum or copper foil or conductive paint, but it can only help so far.
Level is really a separate issue from impedance. You will likely want to add gain somewhere along the line, and it usually is a good idea to get that gain as soon as possible in the chain. A passive DI is the exact opposite of gain, and most active boxes (I think) run unity at best, which is the same thing you'll get from a decent buffered pedal (unless it's a booster of some sort). Either way, you end up having to get the gain at the mixer or some other later stage.
A passive pickup needs a high input impedance in order to pass all of the treble that it can. The input of any pedal designed for guitar or bass will give you this. The output of a pedal doesn't have the inductance that the pickup does, and is usually much lower impedance overall, and will almost always work just fine feeding the impedance of most modern line inputs, or any "instrument" input. Direct connection to some of the lower-Z mic preamps might be an issue, but often also works just fine. Note that if you're running the pedal from an AC adapter you might end up with a ground loop there, but not if it's running from a battery.but many pedals can be used as level boosters etc.. for ex: boss line selector pedal can be used passively as a booster for even 2 output lines..
so what kind of signal do pedals outputing?? and tell me more about that impedance thing pls.
whats gonna happen if i use any fx pedal to that passive bass?? it will act as a active DI?? whats the output? can i connect it to a line inputs on a mixer or souncard? or to a hiZ input on a souncard??
thank u.
