DIY pedal board
  • Thread starter Thread starter famous beagle
famous beagle
famous beagle
Here's a pedal board I designed and built. It's gotten a really good response from my guitar buddies, so I thought I would share the design in case anyone else would like to try it out. It wasn't very difficult to build at all, and it was very cheap.
I had the wood already, so the total cost for me (including hardware and paint) was about $20. If you had to buy the wood, I would imagine it would add about $8-$10 or so.
It's designed so that the top piece comes off, flips over and supports the bottom piece so that the pedal board will be slightly inclined (something I always liked).
The front piece (with the handle) is removable. To close the board, the three dowells on the bottom piece are inserted into the three holes at the back of the top piece. When the board is in playing position, the bottom piece (which is actually on top) is held securely to the top piece (which is on the floor) by slipping its two holes onto the two dowells attached to the top piece.
I painted the whole thing black and used white rubber stripping and white rubber feet (bumpers); it looks pretty sharp, and it works like a dream.
If anyone is interested in building one and has any detailed questions, feel free to ask.
Please forgive my drawings; I did the best I could! :)
I'd inlclude pictures, but I don't have a digital camera. If I get my hands on one, I'll put some up.
There will be one more file after this post (6 drawings in all). The file shown as "s eye view" is supposed to say "side & bird's eye view."
Here is the final picture:
I just realized how crappy these look at such low resolution. If anyone would like me to email higher resolution files, let me know.
I just made a much cheaper (but substantially less cool) pedal board. I just went to Home Depot and bought a sheet of pegboard for ~$4. You know, the 1/4" thick stuff that's full of holes. I took it and scored it on both sides with a box cutter and snapped it in half. I then sprayed each side with spray glue and stuck them together. Then I covered everything in this dark contact paper. After that you can just use some black cable ties and poke it through the holes to ratchet everything down to the board. Now I've got to find some good feet for the bottom. The mounting nails on the ones I bought are too long.
I had another board made the same way back in CA that I just tossed inside of an old Fender Squier bass case. I just yanked out the foam that made up the shape of the bass and used it to carry the board.
((bump))
Did you ever get pix of your actual board with pedals on it?
