Oh, the underestimations people make about DYI stuff…
The “preamp” circuit, simple as it may seem, isn’t all there is to it. Nowhere close.
First, you’ll need a printed circuit board to put it on. So, you can either get some PCB design software and design your own, find a design already laid out for you (a few around at various web sites) or just bread-board the thing using a proto-board. If you have the layout software, you can send the proper Gerber and Drill files off to have some nice boards made for  $30 - $100 depending on the size and quantities, or you can buy around $75(minimum for etching solution, plating solution, pc boards, developer, carbide drill bits that are $5 each and you will break several) worth of stuff to make your own. The cheapest route for a proto is the bread-board route, but it’s not an easy task to wire one up and if you make a mistake it’s an absolute nightmare to track down and correct.
Next, you’ll need a power supply. You won’t need a lot of current, but you’ll need to supply at least two positive voltages and maybe a negative voltage, depending on the preamp design you choose. One of the voltages needs to be +48V to supply phantom power, unless you’re only using dynamic or ribbon mics. The other voltage(s) need to be at what the preamp needs to run on – usually +/-15V  to +/-24V. Plus, all the printed circuit board / proto-board design stuff described earlier applies here as well.
Next, you’ll need a chassis of some sort with the switches, gain settings, etc… marked on it to some extent, or else you’ll be reaching for the phase switch and accidentally hit the phantom power switch by mistake. You’ll have to drill or punch (I’d punch the holes as drilling ends up looking really amateur besides being a real pain) all the holes for line cord, mic in, pre out, gain, phantom power, and other switches you use.
Finally, you’ll put it all together just to find out you accidentally swapped the input and output wires, or the + and – power supply voltages, or something crazy like that. When you fix that, you’ll find it has a bad hum or something else wrong and end up working on that for another month or so because you can’t afford to lose the $$$ you have invested in it - only to find that you should have invested in the PCB design software and laid the thing out really well with a ground plane.
And at some point during all this, you (or in this case your dad) will be wishing you’d just went to Guitar Center and spent the $$$ it on a real nice one that already works.
I’m really not trying to discourage you (really, I’m not) but just trying to point out the facts of the matter. However, if you’re like me, a twisted, demented, pain lovin’ crazy person that likes to learn and doesn’t mind a few hard knocks, be my guest and wear it out!
Also here’s a great forum for do it yourselfers:
http://www.recording.org/cgi-local/ubb/ultimatebb.cgi?ubb=forum;f=6
