frederic
As I've mentioned before, because the joists of my studio floor go the width (unlike the architectural drawings), running the cables between joists is not doable. I've installed toilet flanges in the floor front and back, and was going to elbow that across the garage ceiling. Then I thought of this idea, which I like better - ceiling mounted cable hangers.
Essentially its three pieces of 1/2" square tubing welded together to make a very flat "U", with long 3/8" lag bolts bolting it to the ceiling. Almost too easy.
First picture, material cut to make eight such hangers, second picture, completed hanger before painting.
The completed hanger was welded so the lag bolts go through the legs, thus not requiring any additional material to make brackets, rings, eyelets etc. Simply bolt through. It's strong as hell and weighs almost nothing, thus making it very easy to install overhead. The cable space inside the bracket is about 3.5" to 4" or so, and about 8-9" wide.
Cheap and easy.
Cheap and easy.
