DIY Analog Mixing Console
  • Thread starter Thread starter frederic
Treeline said:
With aluminum, you might be able to do a lot with a tabletop drill press and a milling carriage. In other words, use the drill press as a milling machine. It should work with soft materials.
thanks. what does that mean?
What he's suggesting is one would stick an end mill cutter into a drill press, and then slide the material to be cut/machined underneath, much like one does with wood, using a router.
What a router does for wood, a milling machine does for metal.
However, having tried this, an end mill (cutter) is missing one key ingredient for use in a drill press - a point. Without the point as drill bits have, the end mill will "walk" at least slightly, making for a not-so-round hole and probably damage to the end mill itself.
Drill presses aren't designed to withstand much lateral force against the side of the drill bits, which is why they need to be razor sharp for clean drilling.
A milling machine on the other hand, are much more rigid and uses much larger, higher tolerance bearings, to specifically allow such forces.
This is why one can pass a cast iron cylinder head through an end mill, and "deck" the head flat within less than 0.001" without a problem. Drill presses are $99 for a reason :)
I cut slots in plastic with a router bit in a drill press. I wouldn't try that with aluminum :o
I kinda wish we had seen how this one developed. Seems like a cool project for someone with more engineering knowledge than me... Though I'd like to attempt something like this on a smaller scale.
Sorry to dig up the old thread, I was going through some old favorites...
JM
it seems drawings aren't visible...
is anyone have this ? frederic, have you these ?
thanks
