dachay2tnr
One Hit Wonder
I have a bit of a perplexing problem. Here’s my set-up:
I have a microphone going into Channel 1 of a Mackie compact mixer. I take a direct out signal from Channel 1 and feed it to an RNC compressor, which in turn feeds Channel 1 of a Delta sound card. This is the signal that is recorded.
I also take a return from Channel 1 of the Delta card, and send it back to my mixer going into Channel 7.
Lastly, I have an external reverb unit patched into the Mackie as an insert. By unassigning Channel 1 from the main mix, and applying reverb to just Channel 7, I can have an artist hear reverb in his headphones, without printing the reverb to my recording.
My problem, however, is that the reverb is cutting in and out on me. The problem seems to have arisen only after I incorporated the RNC in my configuration. I’ve had the reverb unit checked out, and the technician can find nothing wrong.
Any ideas on what might be going on.
P.S. I haven’t yet tried removing the RNC from the signal path to see if that clears up the problem. But I can’t think of why the RNC might be knocking out the reverb.
I have a Mackie 1642VLZ. It has Direct Outs, no Channel Inserts. The signal goes from the Channel 1 Direct Out to the RNC to the Sound Card.
