different soundcards
  • Thread starter Thread starter Axis
A
Axis
oompa loompa
hey, I've got a Gadget Labs Wave/496 24-bit/96kHz soundcard. If I buy a Delta 44 would they be able to work together i.e. would I be able to record 8 tracks at the same time. Im running N-Track on a Pentium 4 1.8ghz, 768 ram.
Theoretically, yes. n-Track will allow you to select multiple drivers.
Realistically, no. I mean, yeah, you may be able to get 8 channels of audio in ... but you'll have no way of syncing the two cards to a common clock. Other than the computers system clock, which is totally un-reliable for audio work.
You would likely have better luck if you have the S/PDIF option card for the Gadget and a Delta 66. Then you could sync the two via S/PDIF. Provided that the control panels for each card offers the ability to send/receive clock signal via S/PDIF.
The best bet would be the ADAT Lightpipe option card for the Gadget and any one of the numerous ADAT front-ends.
