G
Grungegod67
What is the difference between a LDC and a SDC mics? And what are the differences in sound....and which one would be better for mic'ing a kick drum?
Hi Grungegod67, welcome to hr.com. When you get a chance, you should read the big sticky thread at the top of the mic forum http://www.homerecording.com/bbs/showthread.php?t=27030 it's a long read... but well worth it.Grungegod67 said:What is the difference between a LDC and a SDC mics? And what are the differences in sound....and which one would be better for mic'ing a kick drum?
AAAARRRGGGHHHHH !!!!!!!!PhilGood said:LDCs are mics with at least 1" condenser diaphragm. "Pencil" mics are usually considered small diaphragm, but that isn't always true. Any back electret mic is a true SDC. The diaphragm can be anywhere from 6mm or smaller up to 14mm. The rest are actually medium condenser mics. Oktava MC012, MXL 603s, Neumann KM183, 184, 185 and the like are medium diaphrams. 14mm to about 25mm are medium.
I know that's splitting hairs but the reason is the smaller the diaphram, the quicker in responds to transient frequencies. The total scope of sound reacts more in unison on smaller diaphragms. The larger you go with the diaphram, the better the bass response.
No, I just don't know where to begin as far as correcting him, so I just didn't bother. But I thought I should at least post a warning.chessrock said:Uh oh.
I think you made him angry.
Harvey Gerst said:AAAARRRGGGHHHHH !!!!!!!!
PhilGood said:mshilarious . . . can probably give better technical explanations.
boingoman said:![]()
Perhaps Phil should do a little reading as well.
So, by your reasoning, the original Neumann U87 (which had batteries) was actually an electret mic? Because all of the particular "pencil" mics you have are electrets, you extend it to say that all "pencil" mics are electrets?PhilGood said:OK, Let me have it!! This is the way it was explained to me a long time ago. ALL of the pencil mics I have before getting the MXL style are back electret mics.
Shure SM94: electret.
Carvin C90E: electret.
AKG C1000: Electret.
Realstic: Electret.
CAD ICM417: Electret.
Guess what?! ANY mic which can be operated on batteries IS AN ELECTRET!!!!!!!
25mm is what most engineers would call a large diaphragm mic.PhilGood said:If you've ever had a pencil mic that took a nine volt or AA. ELECTRET!!!!
These are all smaller than 19mm, right? I understand that the Neumann KM184 style mics are called small diaphrams and I'm fine with that. In reality though if you don't go staight from small to large. do you? I was told by a rep. at NAMM that these were actually medium diaphrams.
Sue me!
Explain my Sony ECM370 which is a 1" electret, an LDC.PhilGood said:Any back electret mic is a true SDC.
Again, wrong on several counts. The "total scope of sound reacts more in unison on smaller diaphragms" statement is just bullshit. It's because there's a smaller area to prevent disturbing the sound field, and that gives SDC's the advantage in off axis response over LDC's.PhilGood said:The total scope of sound reacts more in unison on smaller diaphragms. The larger you go with the diaphram, the better the bass response.
Harvey Gerst said:The problem is that you've taken a few isolated examples of "some things", and extended it to include "all things".
Harvey Gerst said:So, by your reasoning, the original Neumann U87 (which had batteries) was actually an electret mic? Because all of the particular "pencil" mics you have are electrets, you extend it to say that all "pencil" mics are electrets?
Harvey Gerst said:I have a pair of really obscure 1/2" Akai "pencil" cardioid mics that have a nice 12au7 inside them. I had a pair of nice 1/2" omni Capps pencil mics back in the 60's that used 12ax7's.
I also have a nice pair of Fairchild F-22's which runs off batteries - also a 1" diaphragm, and also not an electret.
Harvey Gerst said:25mm is what most engineers would call a large diaphragm mic.
Harvey Gerst said:Explain my Sony ECM370 which is a 1" electret, an LDC.
Harvey Gerst said:Your last post (showing a quote from some place), while interesting and quite factual, has nothing to do with your statement errors. Small omni electrets ARE a great value, and I've been hawking the use of the Behringer ECM8000's here for a long time, exactly for that reason.
Harvey Gerst said:I'm not trying to dis yu Phil, but I've been fighting misinformation for years.
