Did everyone struggle to learn to mix...
  • Thread starter Thread starter phlopip
Been mixing for a heck of along time live and studio and you know I learn something new or a different approach almost every day.;)
Take a look at the thread about the EZ MIX plug in.:laughings::laughings:
:cool:
Personally I already have a good idea of where in the sound stage things should go...and tend to put them on the same tracks time after time...so usually my normal settings are a good starting point and I tweak from there...
Believe it or not in a commercial situation people will do the mix in a very short amount of time...working on a mix over a weeks time like at home wouldnt ever happen.
This is another good point. It's become kind of de rigueur that a mix has to take several hours and even days but shouldn't it just take as long as it takes ? They'd do almost instant mixes back in the 50s and 60s. Which is not to be nostalgic, just to show it can be done fairly speedilly.
They also have thousands of hours of experience behind them. Plus I'd expect it to be pretty fast if that's all they do all day every day
Yeah, a lot less processing back then too..
Plus...I think back in the early days, most of the mixing was already done in the tracking stage.
Seems like it anyway.
Another thing that helps me out too, is I take a song from a commercial CD and insert it in as a track in the mix. I A/B my mix to that when I'm mixing the drums. Especially the overheads.
The best "trick" I can think of is to get things to sound how you want them to before you ever mic them up. When you're tracking, play dynamically to the mix in your headphones so that you wind up with a "faders up" mix before any adjustments or post processing. Make a safety copy of this mix to compare your processed mix to. Sometimes it doesn't need much at all, and sometimes it was better before you did anything to it.
Maybe I take for granted what I've learned playing live.... I guess I just know what a snare "ought" to sound in relation to a kick drum, and in turn to a bass... And how a rhythm section "ought" to sound in relation with the guitars. That's what I think of as mixing mostly, the dynamic relationships between the instruments and the silence.
Otherwise, I guess I'm looking at sounds themselves and getting them to sound right pre and post-processing. If I don't know how to do that, I'll want to learn how before I'll track a thing.
Also: You can't fix it in post. Retrack it or rethink it.
