Dial numbers
  • Thread starter Thread starter ad0lescnts
A
ad0lescnts
Does anyone know where i can find a clean image of the circular numbers that go on an LA2a behind the gain and peak reduction knobs? I need the image so i can use it on decal paper to put on my home project.
Any suggestions are much appreciated
Thanks,
T
Your best bet will be to make some up in Photoshop or similar program.
Here is Universal Audio's LA-2A Session Recall Sheet (PDF)
You *might* be able to "save as JPG" (not sure - It may require Acrobat, not Acrobat Reader). If not, boost it up to full screen size and hit your "Print Screen" button (which, for the uninitiated, takes a snapshot of whatever is on the screen - You can then paste this image into any image editor).
AWESOME! that's just what i needed! thanks massive master. You can just use the graphics select tool and copy and paste into your image editing program.
thanks again!
T
