Delta66/Omni users please read
  • Thread starter Thread starter SLuiCe
SLuiCe
SLuiCe
Is the Audio Buddy (or other preamps) necessary (or even beneficial) with the Omni I/O box? I'm checking out condenser mics, and wondering if the Omni's built-in preamp is sufficient. Will a preamp like the Buddy improve the quality noticably?
Thanks in advance!
-Tom
The Omni I/O has two built in preamps which are said to be the same as were used in the DMP2 preamp. I find them to be quite sufficient for use with any mic I've tried. The preamps are quiet, have plenty of gain, and are very neutral sounding to me. If you need more than two channels of mic pres, then the addition of an Audio Buddy/DMP3 or other will also work.
Thank you LooneyTunez for the quick help. I'll hold off and see how I do without it.
Thanks again!
Tom
Just wanted to add a ditto. I have the Omni as well. I have a couple of dynamics and an SP C-1. The Omni pre's and phantom power work just fine for the C-1. If two channels is all you need, you're all set.
lou
