K
Kaybee Brutal
What mics would be best for death metal drums
Honestly it doesn't matter at all because they're all sample replaced anyway. Any decent pair of SDCs for overheads is all you really need to be concerned with when recording drums for any kind of metal. Close mics are almost never actually used beyond triggering something else.
...deja vu, lol
As I stated, I'm not really a recording guy so much, I mainly use this forum to learn about different mics so I have to ask. If you're triggering samples, what's the point? Not asking to be a PITA but don't you want to hear YOUR drums, not somebody else's? I don't understand the reasoning behind this.
I think you missed my point----------I don't have ANY opinion on it, I'm simply asking a question as I don't understand why you would do it. What would be the situation?---bad drummer, drums, mics? etc......The discussion is hardly nonsensical if I'm trying to learn something.
There are a few reasons for this.
1. Death metal drums tend to be larger than life, very bright, and have very little decay. By the time you EQ the drums to sound like this, the cymbals bleed is really loud and crappy sounding.
2. The faster a drummer plays, the less force the can hit the drum with. when you don't hit a drum with a certain amount of force, you lose the attack and e d up with only resonance...exactly the opposite of what is needed to cut through a wall of guitars.
3. To cut through a wall of guitars the dynamics have to be more consistent than most drummers can manage at those speeds.
The death metal drum sounds can be gotten using real drums with a lot of EQ and compression, which is where the samples come from. A lot of times sampling is a time saving method.
That's not to say that there are not drummers out there with the speed and power to pull it off, but the Gus that can are few and far between. Jason Bittner is one of those guys.
No. Just about anything that has any big production value will at least have some sample enhancement. This sort of thing has been going on since the late 70's - early 80's. We all have been listening to it for 30 years.Would any of you say that using samples for metal is more common than other genres? (for the stated reasons)
There are some obvious exceptions like Jazz, blues and other raw and organic genres, but anything mainstream has about a 90% chance of samples being used.
That being said, I have done some metal albums without using samples. It really depends on the drummer and the type of production you are trying to achieve.
A lot of times i will add a triggered sample to the miced snare to add what the real snare doesn't have. For example, if i have a snare with good crack and a lot of depth, but doesn't have the right amount of high end, I will add a sample that has that strainer sound to complete the snare sound that I want. The same goes for the kick.
This is good Jay - it is about the only real reason I use samples while recording.
