B
		BillyKid
Hi,  I would have used a smilie if they had one that looked like someone begging.  I have had my 840 since they first came out.  I have made a bunch of recordings, but must confess to being a total idiot.  I KNOW you can make terrific recordings with these thing, but clearly, I am doing something wrong.
I recently tried deducing from the demo tape that came with it what they are doing right and I am doing wrong. I can not record anything that sounds remotely that good (musicianship aside). I have struggled on stubbornly, unwilling to ask for help. I tried applying the effect they used on demo song "Mercy Blue" to a dry recording of my own and routing the same effect in the same way it appears to be routed "loop:dir ff" on the demo and I get, essentially, nothing.  Clearly, when you route these effects directly to a track, you get junk, but when used for the over all demo mix using "loop:dir
ff" on the demo and I get, essentially, nothing.  Clearly, when you route these effects directly to a track, you get junk, but when used for the over all demo mix using "loop:dir ff" it sounds just fine.
I know it's a pain in the ass, but could someone please, please, tell me specifically how to set up an effect (say, preset reverb + reverb U15, which is used on Mercy Blue) and get a decent result? I am assuming I can just easy route and record dry and then add the effect at mixdown and get the same result. Please write me at lcarkuff@stny.rr.com Thanks sincerely, doug
ff" it sounds just fine.I know it's a pain in the ass, but could someone please, please, tell me specifically how to set up an effect (say, preset reverb + reverb U15, which is used on Mercy Blue) and get a decent result? I am assuming I can just easy route and record dry and then add the effect at mixdown and get the same result. Please write me at lcarkuff@stny.rr.com Thanks sincerely, doug
