A
Absinthe
Could someone explain what a de-esser is? how it works, should i get one, what do I use it on, etc...
That would be really helpful,
Thanks!
Thanks!
It's essentially a compressor with a built-in sidechained EQ. You'd set the EQ trigger to a frequency range that's generally associated with sibilance, maybe around 4kHz-6kHz and the compressor will clamp down whenever that frequency range goes over a certain threshold. It's mainly used on vocals to tame sibilant peaks from hard C, K, and G kinds of sounds, and S sounds.
You could tweak the Nova as a de-esser to some extent, sure. If you can find SpitFish somewhere, all the better. Still one of the greatest de-esser's I've ever used.
