Daisy chaining audio cards.
  • Thread starter Thread starter Magarious
M
Magarious
HI guys, right i have a m-audio firewire 410 audio interface. Ialso have a built in sound card that has 3.5mm outputs for surround sound. As i want to usemy 410 as my main card and use my other card for surround playback can i somehow link them together. Cheers
No, You wouldn"t want to link them together as they both probably won"t work at the same time.....
If you want to use your Built in sound card you would just go into your audio device settings and disable the 410 and enable the sound card and when you want to use the 410 you would just change the setting back to the 410....
Your 410 basicly replaces the sound card as your Audio Interface so they both can not be used Simutainiusly.....
Cheers
