Daisy chain midi instruments? (newbie question)
  • Thread starter Thread starter santiu
santiu
Rock-scientist
So, I have two midi instruments I use: a keyboard and a drum set. I'm getting tired of swapping cables into my interface every time I switch instruments, so I was wondering if there's a way to hook them both up at the same time.
I never use the two instruments at the same time, and they are both used as inputs to my computer. I don't use either for generating any sounds. The drum module only has two midi jacks "in" and "out/thru". the keyboard has three "in", "out", and "thru".
thanks a bunch for any help :D
This will probably fill the bill.
If you expect to be expanding your controller set anytime soon they make a 'quadra merger' too...
Get a MIDI book....
You will find that you can daisy-chain your devices if you assign each to a particular channel.... (you can have 16 channels on a "chain".)
