D.C. offsets
  • Thread starter Thread starter crazyhorse
C
crazyhorse
Do any of the versions have a built in method of resetting a 0 voltage line? I got a plugin but it doesn't work. I'm having to make each track a wav and send out to d.c. offset in another program then import back in.
Same question here, I'm still doing DC offsets external (SoundForge). Would really appreciate if someone can help on this topic.
This might be useful: put the DC offset plugin onto the track in the console view, then select the track in the track view, and select 'Mix-down audio' from the tools menu. This will work in Version 8, I'm not sure about versions before that.
ignore that last bit...
Just right click on the audio clip you want to fix, go to audio effects, choose your DC offset plugin.
In the case of AnalogX DC Offset, you then have to hit audition, and then Analyse... that way the plugin gets enough info to fix the offset, then hit okay, and your set.
William Underwood
Worked like a charm! Thanks a million!
[This message has been edited by crazyhorse (edited 01-03-2000).]
