SpotlightKid83
I am using Cubase VST32 and Battery together, I write the drum sequences on Guitar Pro 2.16 and then manipulate the velocities and everything on Cakewalk Pro Audio 9 (I'm just used to do it that way), but when I play back the sequeneces on Cubase VST32 through Battery some of the toms don't sound, the corresponding cells don't even light up
. I suppose there maybe is a difference in the drum map, when I play the sequence on any GM synth it plays fine, but as I said, when I play it through Battery some samples don't sound. If anybody can help me solve this I truly appreciate it.
Thank you
. I suppose there maybe is a difference in the drum map, when I play the sequence on any GM synth it plays fine, but as I said, when I play it through Battery some samples don't sound. If anybody can help me solve this I truly appreciate it.Thank you
