NL5
Unpossible!
OK, I probaly do things in a wierd sorta way, but I am wondering if it is hurting my final mixdown. What I do is take all my recorded tracks and mix them to 16 stems, those go out to my Ghost for summation, then that mix is sent back into the converter and recorded on a stereo track inside of the project. Then, I take that track and send it to a bus, throw a uv22 on it, and export it to a .wav. Is cubase "mxixng' the two sides of the track slightly, or should it simply adjust the bit depth/rate and leave each half of the stereo track exactly as it was recorded?
The reason I ask is, there seems to be quite a difference from the "live" sound (playback of the 16 "stems") and the final mixdown. I expect a subtle difference, but it is more than subtle.
Thanks.
Thanks.
