Cubase LE Help
  • Thread starter Thread starter riseabove
R
riseabove
I have scoured the internet and found nothing that has helped my plight!
I have been running Cubase LE on my MacBook for about a year and have had minor crashes but nothing that quitting and then reopening Cubase couldn't fix.
Yet, recently I have been running Reason 4.0 on my mac and ever since then Cubase will not run. I have tried uninstalling and reinstalling both programs. Cubase begins to start up and as it says its loading VST's on the little Cubase startup screen, it crashes and I get an error report.
It has been suggested that a VST might be causing this whole conundrum, but for the life of me I haven't been able to figure out how to clear out any VST's I may have downloaded from the internet.
My biggest fear is that this is all caused by Reason, I know many people have had trouble running the two together but I feel as if I should be able to at least have both of them on my computer.
So can anyone help diagnose my problem and help me fix it? If it involves clearing out VST's I downloaded how do I do this?
If it helps, I could post the problem details I get when Cubase crashes
I use Windows but this should work for Mac:
Locate the folder (or folders) that is set as the VST plugin folder in Cubase and move it to another location so that Cubase won't be able to read any VSTs. This should help eliminate (or not) whether the problem is with plugins. It would be better to do this than to delete your VSTs as chances are you will want to keep them :)
If Cubase loads up ok after moving the folder then this means that there is a problem with a plugin in which case you need to consider which plugin may be causing this problem.
I've never used Reason so I don't even know if it uses VST plugins but if it does you need to check whether it has installed VST plugins into the Cubase plugins folder and if so then it is likely it is these VSTs that are causing the problem.
Oh and could you post the error log you mentioned?
Thanks,
I am not the most enlightened person in terms of audio recording and technology but I do not believe Reason is involved in any type of VST. Yet, as cubase Le loads and the lower left hand corner box that reads "initializing:(insert various parts here)" it always crashes as it reads "initializing:VST"
I'll give the folder thing a shot when I get a bit more time. Finals are bogging me down.
Here are the "problem details" (this is long, idk how to best post this):
Process: Cubase LE [686]
Path: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE
Identifier: com.steinberg.cubase.se.oem
Version: 1.0.8 (1.0.8)
Code Type: PPC (Translated)
Parent Process: launchd [86]
Date/Time: 2009-05-31 17:54:38.812 -0400
OS Version: Mac OS X 10.5.6 (9G55)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c0000007
Crashed Thread: 0
Thread 0 Crashed:
0 translate 0xb80bcd58 0xb8000000 + 773464
1 translate 0xb80b7007 0xb8000000 + 749575
2 translate 0xb80d49c0 0xb8000000 + 870848
3 translate 0xb813d75f spin_lock_wrapper + 4259
Thread 1:
0 ??? 0x800bc1c6 0 + 2148254150
1 ??? 0x800c39bc 0 + 2148284860
2 translate 0xb818b6ea CallPPCFunctionAtAddressInt + 202886
3 ??? 0x800ed095 0 + 2148454549
4 ??? 0x800ecf52 0 + 2148454226
Thread 2:
0 translate 0xb81529ef spin_lock_wrapper + 90931
1 translate 0xb8183633 CallPPCFunctionAtAddressInt + 169935
2 translate 0xb81861e2 CallPPCFunctionAtAddressInt + 181118
3 translate 0xb80dfb0b 0xb8000000 + 916235
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000004 ebx: 0xb80bcd30 ecx: 0xc0000003 edx: 0x0000001f
edi: 0xc0000007 esi: 0x80308c60 ebp: 0xb7fffa08 esp: 0xb7fff9d0
ss: 0x0000001f efl: 0x00010202 eip: 0xb80bcd58 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0xc0000007
Binary Images:
0xb8000000 - 0xb81d7fe7 translate ??? (???) /usr/libexec/oah/translate
Translated Code Information:
Rosetta Version: 21.03
Args: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE -psn_0_385118
Exception: EXC_BAD_ACCESS (0x0001)
Thread 0: (0xb009a83c, 0xb81529ef)
0x00000002: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : + 2
0x958ea558: /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation : _CFRunLoopRunSpecific + 1816
0x90a00f88: /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio : HALRunLoop::OwnThread(void*) + 216
0x90a00dc4: /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio : CAPThread::Entry(CAPThread*) + 108
0x94e3c17c: /usr/lib/libSystem.B.dylib : __pthread_body + 40
0x00000000: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : + 0
PPC Thread State
srr0: 0x00000000 srr1: 0x00000000 vrsave: 0x00000000
cr: 0xXXXXXXXX xer: 0x00000000 lr: 0x94db2080 ctr: 0x94dab150
r00: 0xffffffe1 r01: 0xf0080550 r02: 0xa08c9e48 r03: 0xf0080930
r04: 0x03000006 r05: 0x00000000 r06: 0x00000450 r07: 0x00006b03
r08: 0x00000000 r09: 0x00000000 r10: 0x00000004 r11: 0xa0742694
r12: 0x94dab150 r13: 0x00000000 r14: 0xa08b7478 r15: 0x7fffffff
r16: 0xffffffff r17: 0x00000000 r18: 0x00000000 r19: 0x00000000
r20: 0x00000000 r21: 0x00000000 r22: 0xf0080930 r23: 0x00000000
r24: 0xf0080930 r25: 0x00000450 r26: 0x00006b03 r27: 0x00000000
r28: 0x00000000 r29: 0x03000006 r30: 0x03000006 r31: 0x958e9e48
Thread 1: Crashed (0xb7fff9d0, 0xb80bcd58)
0x00440800: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 4454400
0x00440a94: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 4455060
0x00440c10: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 4455440
0x004414ac: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 4457644
0x0042c168: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 4370792
0x0061bd34: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 6401332
0x00586f34: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 5791540
0x00054d40: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 343360
0x0011fb90: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 1174416
0x00042584: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 267652
0x000423b4: /Applications/Cubase LE.app/Contents/MacOS/Cubase LE : __mh_execute_header + 267188
PPC Thread State
cr: 0xXXXXXXXX xer: 0x20000000 lr: 0x00440854 ctr: 0x94e02740
r00: 0xc0000003 r01: 0xbfffd2e0 r02: 0x00b507f4 r03: 0x170c74e0
r04: 0x00000018 r05: 0x009df738 r06: 0x00000008 r07: 0x00000001
r08: 0x00000010 r09: 0x00000004 r10: 0x00000002 r11: 0xa0883e48
r12: 0x94e02740 r13: 0x00000000 r14: 0x00000000 r15: 0x00000000
r16: 0x00000000 r17: 0x00000000 r18: 0x00000000 r19: 0x00000000
r20: 0x00000000 r21: 0x00000000 r22: 0x00000000 r23: 0x00000000
r24: 0x00000000 r25: 0x00b57a24 r26: 0x00b57a28 r27: 0x00e51927
r28: 0x00441448 r29: 0x004407f4 r30: 0x170c74e0 r31: 0xc0000003
Did you get Le with a hardware package?
Hmmm. I would still try moving the folder. When Cubase says Initialising VST, VST may not necessarily refer to plugins but the actual Virtual Studio Technology system of which Cubase is based so perhaps Reason's ReWire (this is just knowledge I've heard from others) may be conflicting. Perhaps another user can interpret that error message as it's incoherent to me.
Dremits, this is somewhat of what I have been thinking, except that when I open Cubase I quit Reason and it still does not work. I am severely hoping that having Reason's software on my computer does not conflict with Cubase's software.
And yes, I did recieve Cubase LE with a hardware package for an Alesis Firewire Mixer
Probably a dumb question but do you have your mixer installed on the mac?
You should update your drivers:
http://www.alesis.com/contentmgr/showdetails.php/id/1171/tt/5
If the DVD that came with your Alesis product includes the code "7-22-0021-B" in small type at the bottom of its printed text, you have CubaseLE4 and can obtain a free update to version 4.1.2 directly from Steinberg at http://www.steinberg.net/index.php?id=880&L=1.html. This update fixes bugs and adds new features. It is recommended for all users.
dremits reply is correct.
Thanks,
I was having problems running Cubase LE 4 on my PPC iMac G5, and the only thing I did was to change the offending plugin that wasn´t allowing me to open up the program (in my case, it was the BIAS Freq-4 Plugin).
After I changed the location of the plugin on my folders it had problems with another plugin. I changed the location of that one also.
After that change, it opened up normally.
Thanks a lot dremits!!! You really saved me on this one!!!
Greetings to everybody from Nuevo Laredo, México!!!
