CUBASE 10 & HALION SONIC SE3 - MISSING INSTRUMENTS/VOICINGS?
  • Thread starter Thread starter hnia6
hnia6
hnia6
Member
Years ago, I upgraded from Cubase Artist 6 to 10.0.6 Pro. I have no access to Artist 6 anymore. When I open many of my projects, I get the attached popup.
Some Files
Some Files256×126 7.24 KB
I found that some Halion Sonic SE3 (HSSE3) instruments or voicings can’t be heard. Examples include MelloStrings, Double Bass, Backing Section, Hard Grand Piano, Ambient Kit, Cello Duo and others. I'm not missing any actual audio files such as wav. I'm only missing voicings with Halion Sonic tracks.
There's no issue creating a new track and HSSE3 will work great with available voice options.
I am worried that I’m missing a bunch of voices/instruments. This has been driving me crazy. Hopefully, someone can help me figure this out.
Get this all the time on older projects. Often annoyingly on old drum kits. I had a period where i used many kits, particularly the maple kit, yet while my home studio system finds maple samples, the system in the office, with pretty much identical installation hasn’t got them. I thought it was 32 bit vas 64 bit issues causing it, but i copied entire libraries from home, put them in the same place in the office and they don’t work. One missing halion instrument i did cure because checking home vs office i found it installed in a totally different and random location. Have you tried finding a preset that loads and then searching for its location to see what else is in the same place. When you say you have not lost the wavs, do you mean the samples are findable and intact, but just will not load?
Hi Rob.
No, I wasn't referring to the samples. I didn't loose actual audio waves that I recorded via microphones. I searched for specific voices and/or presets by name. No luck.
Is all the VST sound supposed to be in C:/Program Data/Steinberg/Content/Halion/VST Sound? I have 46 VST Sound Archive files there and that's definitely a light amount.
Check out the attached screenshots. The first is the location of the above noted 46 files. The middle image shows 6 more sound archives located in C:/Program Files/Steinberg/Cubase 10/VST Sound. Why segragated? I can't tell what voices they are.
Are the VST Sound Archives the actual voice files? (I'm just a dumb non-blonde girl with a nice ass! hee hee)
The third image shows an example of a project with "Halion Cello" missing. I see the midi - it all looks normal, but no sound. when I try to load a voice, it shows only ONE option for any stringed instrument, which is a preset I created a long time ago. I guess presets don't necessisarily fall victim to this nightmare.
I just did a search for the extension, ".vstsound" and they're all over the place. I have 455 in total, but not all are dedicated to Halion.
I have another folder in my A Drive (intentionally separated from the boot drive) at: Documents/Applications/Cubase 10.5 Installer_win/Cubase 10.5/Additional Content/VST Sound/Halion Sonic SE Content. - I downloaded 10.5 and thought it was a free update. Found out it wasn't and uninstalled it. This stuff was left over. It looks like most of it is dublicative of the 46 files referenced above.
If you or anyone can help me solve this aggravating nightmare, I'd be so grateful. I think most everyone just gives up and spends $$$ on the latest release?
The sample files. Cubase is looking for X sample set in Y directory on drive Z - or any version, and somehow one of two things has happened, the actual sample file - which can be any file type really - have been moved, or deleted, or more often, cubase is looking in the wrong place. in the vsti manager, there is an option to see vsti's that are active and those on a blacklist - ones that perhaps are now too outdated or the wrong file types for the current software. It also has a section where you add a path to wherever the samples are hiding. The idea is to search your drive for the name that is missing and see if you find them hidden away somewhere - if so you can then add that location to the path at the bottom, and on startup cubase will look in the usual places and then pop off to any other location you have highlighted.
Here's my VST Plugin Manager. Do you see anything unusual?VST Plugin Mgr.webp
Please elaborate, I'm not a pro with this. I'm surprised that this is a lot of instances... but would you observations have anything to do with missing voicings?
I have loads of instances of the same thing running? Hallion can run within one live instance lots of different sounds, but i use lots of instances each with one. Just easier for how i use cubase? However, vst2, is far trickier. Its been gone 7 years, so while cubase 10 and vst2 will carry on working, and updates windows does can break things. Can you find the data for the working sounds you have, and then look in that location for differences with the ones that dont work?
What about this... when I am on one of my tracks with a missing instrument (in this case, Halion Sonic SE3 "Double Bass," and I go to "Load Program" under "All Instrument Sets," I see the attached - no HSSE3, which means no voices under that program are shown, right? Am I on to something here? Shouldn't I see all my VST Instruments?Load Program.webp
If you used to get the halion icon, then yes. You need to find the location all of those are actually sitting, then compare. For completeness. Do you have anything in the blacklist?
Blacklist is empty. I can't say if the halion icon ever showed. Seems like it should. I am so frustrated.... But check out the two images below. There's two locations that VST2 should appear and they don't if you look at my file explorer. I searched my entire C:/ for VST2. Nothing. So, is this the problem? They're just gone? I imagine my missing stuff is all VST2 from my Cubase 6 days. Missing VST2.webpMissing VST2 B.webp
I seem to recall:censored: having an issue once with Halion Sonic. I recall certain samples from older projects just didn't exist in newer version of Halion. Like they just were not there in the updated version and no way to get them back.
Sorry I can't be of any help. I do understand your frustration tho. :censored:
Just a thought? The old steinberg activation system with elicensers and real dongles was retired and people converted to their current online system. I wonder if this might have been the trouble? Did you shift to the new system? Maybe the losses occurred then? Steinberg were very helpful when i had a few issues and they fixed the simon Phillips drum stuff that i lost access to. It wasnt just a few kits like your missing sounds, but all my jazz kits vanished.
Jimmy, I think you're right.... sadly. Though, I wonder if there's a way to get those old voicings. Do you know? What's the proper name for them? Presets?
Also, If I ever find those old presets or some other free ones, where exactly do they belong?
Rob, I had this problem before all that elicenser crap started up. I think it must have happened when I upgraded from 6 Artist to 10 Pro. I think it's lousy that Cubase makes the old voicings disappear - they should all carry over into the new Halion or whatever...
Might just have to open the old files in C6 and export them so you can fly em into the C10 project.
Try asking ChatGPT. I have solved quite a few Cubase issues lately via that.
Well, in fairness to Steinberg, they cant stick with an ancient out of date system for ever. They did send people reminder after reminded, but of course i left it till the last minute and lost a lot of sounds. I got virtually all back, plus one that hadn't actually worked for years. They restored that for me too!
