P
ProJee
Hi,
I'd like to purchase Rode NT-2A condenser mic and connect it to my PC... somehow. (never used condenser mic with external phantom power before)
I have Creative X-Fi platinum Fatal1ty Champion series soundcard, equipped with the front panel, which has a mic input with pre-amp.
What would you recommend?
I could:
a) buy a phantom power and connect the mic output into the soundcard's preamp.. but I'm not sure if the preamp has enough gain/quality.. I can hear noise when the knob is at >80% of its max. position - I think it's even if there's no mic plugged in.
(the X-Fi should have 109dB signal-to-noise in the tech. specs, maybe it's not valid for all inputs?)
b) spend some more money (up to $250) for some kind of external USB soundcard with phantom power and HQ pre-amp... but these (AFAIK) have higher latencies and maybe lower sound quality than my current soundcard - dynamic range of the mic is 140dB. M-Audio MobilePre USB which i've checed out recently has dynamic range 88dB, so the Mic would be an overkill (?)
c) any other solution.
I would simply like to get most of that mic without losing the quality somewhere in the input chain... and avoid spending money for something, that has lower quality than my current soundcard..
thanks
I could:
thanks
