rjt
I am cross posting this to the Cubase forum as well.
I just bought the Steinberg "Mastering Edition" which is supposedly Direct X compatible. It has 6 plug ins. I am using Cool Edit Pro 1.2a as the host program. Five of the plug-ins work find, but the Spectralizer gives me the following error message:
"unable to connect with the specified filter. Most likely this is because the output of the specified filter does not match that of the selection-mono vs stereo. If you are working with a stereo waveform, limit the selection to a single channel at a time. If you are working with a mono waveform, convert it to a stereo waveform where both channels are identical."
Well, it does not matter if the waveform is stereo or mono or if stereo/mono is clicked on the plug-in...same message. I have reinstalled the plug in (x3) and even tried reinstalling it in a different directory.
I have Windows 98 and as far as I know the latest Direct X (7) and Direct X run (6) (I downloaded the latest versions from Microsoft about a month ago to run another plug in).
Any suggestions, comments or sympathy are appreciated.
