J
jeff0633
Member
I am using sonar 2.2 I load live synth pro after loading a GM midi file. I set my pan and reverb. Song plays fine. On some midi's, when I stop and hit rewind, and then play again, I lose my panning and reverb. On some midis, this doesn't happen. It seems there must be some kind of sysex command or controller command or something. Now if I stop the midi file playback and DON'T rewind, then hit play again, then it will keep my panning and reverb. It's as if it is resetting at the beginning of certain midi files. What should I look for and how do I figure out what is causing this, and how do I stop it. Let's say I want to export the midi to audio using the synth, but when I do, no matter how carefully I set my pan and reverb to get it just how I want it, when I rewind and hit export to audio, it comes out panned down the middle again after the export. This is driving me nuts.
Jeff
Jeff
