I like to think of it this way- A small diaphragm mic is like the little glass peephole in a motel door. It sees big, because it is small. Because the diaphragm is small, it is therefore also light, which tends to make it sensitive. SD mics respond well to fast transients, when things go from quiet to loud, and back again, very fast (drums are a good example). Although large diaphragm mics are more commonly used for recording vocals, there are a number of SD mics that have been used for vocals with good results. I am a fan of AKG C2000B, an SD mic that works just fine on vocals. The Beatles used Neumann KM84's for vox on several occasions, which is a *very good* SD mic. The biggest problems with SD mics for vocals are 1.- their sensitivity tends to make them prone to "popping" on aspirated consonants, like "P", and- 2. their excellent off-axis response (seeing big because they are small) makes them subject to mic bleed, picking up other stuff along with the vocalist. If you have a good room with very little ambient noise, good control over your P's, and a good pop filter (or even 2, a couple inches apart), there's no reason why you can't record perfectly good vocals with an SD. It should also be said that LD mics can pick up ambient noise and pop perfectly well, also. There's no such thing as a free lunch.-Richie
