Computer Isobox!!!
  • Thread starter Thread starter Blue Groove
Blue Groove
Blue Groove
Anyone know of an inexpensive one or how to build one that cools well enough for a :confused: VERY :confused: hot comp?
an isolation box is'nt going to make your computer run cooler.
This one will :D
cooler
I know it won't keep it cooler, but I'd rather not fry a $1k processor. Good venting, low volume.
Is your problem noise or heat? :confused:
For noise, you could try an AcoustiCase. Also replace stock fans with 'silent' 120mm fans, get sidemounts for your harddrive, get a silent power supply, etc.
And if you're going to isolate it you'll need ventilation, or it will overheat.
noise
Noise is the problem, but whatever I put it in needs to vent well. The computer already runs hot, and if you stick it in a box with normal comp ventalation, then it will overheat. :cool:
Look into watercooling kits. Without seeing more specifics on your situation I can't get more specific than that.
nope
Unfortunately another room is NOT a possibilty :( I alerady am using a third of the house and I'm married (you can guess where this is going)
Actually you could build a good case and not worry about ventilation - as micter said use watercooling. It's fairly expensive but an arctic cooling system can get your processor down below 0 and you can just run the tubes in and out of the case through sealed openings.
