P
Purpleb
I am using mbox with protools. All I record is vocals, do you think i need a compressor in the recording process before it hits the mbox? If so any decent ones for a good price?
A second vote for the FMR RNC.tc4b said:I am definitely one of those who compress going in for vocals, but I think I'm in the minority. I use (and love) this one:
http://www.humbuckermusic.com/1001.html
Yes, before it hits the converter. By way of an insert (?) or a separtate path.(?)Purpleb said:...doesn't the mic have to go to the pre then the compressor then recorder?
You could get away with that if the mic's hot enough -a condensor can do it.Purpleb said:I usually just hook my mbox right up to the mic turn the phanton on and go. I don't have a hardware mixer or anything else.
Can the process go like this: mic to compressor to mbox?
Only if you have an outboard phantom power unit. The compressor won't pass the phantom power through it.mixsit said:You could get away with that if the mic's hot enough -a condensor can do it.
Farview said:If you are using the m-box for it's preamps, don't worry about compressing on the way in.
Because there is no way to insert the compressor after the preamp. So, in order to use a compressor, you need to also buy an outboard preamp. It's just a waste of time unless you buy a preamp that is better than the one in the m-box, which will cost a decent buck then you have to get the compressor.Purpleb said:Just wondering why not?
